Loyale TPS question
thanks for the replies, ended up going to PnP in Kelowna and grabbed 3 loyale TPS's, an EGR valve, and a vacuum sensor of some sort that I broke on my car. Swapped out TPS with a different one and the hesitation is noticeably gone. However, just puttering along and slightly changing acceleration causes stuttering hesitation still. So far I've replaced cap and rotor, plug wires, plugs (I like to do those when I get a new car anyway), TPS, Coolant gauge temp sender, EGR valve (still have to clear code to see if it is any good). Next I think I will get a new CTS as I just noticed the other one on the thermostat housing. So far i'm making progress.
