Phizinza Posted November 13, 2009 Share Posted November 13, 2009 So I plan to build up a Liberty/Legacy as a bit of a race car to replace my 83 wagon. I'll be doing custom struts most likely so no rubbage problems as I'll use smaller springs and spring perches. But I want to fit 30 to 31 inch mud terrains to it and was wondering how much lift (body and suspension) people think I would need to do so? I'll be whacking the heck out of the guards and cutting the fenders back a lot, no problems with that. But 31" tyres are pretty big so I was thinking I need lift.. I also need lift (about 3" or more) so I don't just float in the puddles, need that body up high so she doesn't just boat it! Thanks... Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted November 13, 2009 Share Posted November 13, 2009 i did 4" on this legacy 2" plus the outback struts those are 30 x950 tires Link to comment Share on other sites More sharing options...
Phizinza Posted November 21, 2009 Author Share Posted November 21, 2009 Ok. So 6" total lift will fit 30"s under it. That's cool Not to high then. Cheers Link to comment Share on other sites More sharing options...
joostvdw Posted November 27, 2009 Share Posted November 27, 2009 I think Scott meant 4'' total. 2'' bodylift and 2'' lift from the outback struts. Link to comment Share on other sites More sharing options...
Phizinza Posted November 28, 2009 Author Share Posted November 28, 2009 Oh, I see. So the Legacy's have much more room then the older EA81's then... Well at least I know I can fit the tyres I want to run under one now. Thanks Link to comment Share on other sites More sharing options...
Gloyale Posted December 8, 2009 Share Posted December 8, 2009 ONly problem is that you won't have the clearance at the spring perches. Scott's blue sedan above has a lift design that allows for the bigger tires, and wide offset wheels. Just using Outback struts and a conventional strut/body block lift you will be limited to about a 29" no matter how large the bodylift. Link to comment Share on other sites More sharing options...
'86 oopsie Posted December 10, 2009 Share Posted December 10, 2009 I think Scott meant 4'' total. 2'' bodylift and 2'' lift from the outback struts. I currently own Scotts old Legacy, it has 4" blocks in the front with 2" blocks in the back and Outback struts on the back only. Link to comment Share on other sites More sharing options...
Gloyale Posted December 10, 2009 Share Posted December 10, 2009 I currently own Scotts old Legacy' date=' it has 4" blocks in the front with 2" blocks in the back and Outback struts on the back only. [/quote'] Correct me if I'm wrong, but isn't the lift from extensions on the bottom of the strut, between the strut and Knuckle? It works, but is different than most of the "conventional" tophat style blocks most lifts use. It allows for more tire height. Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted December 10, 2009 Share Posted December 10, 2009 Correct me if I'm wrong, but isn't the lift from extensions on the bottom of the strut, between the strut and Knuckle? It works, but is different than most of the "conventional" tophat style blocks most lifts use. It allows for more tire height. Gloyale you are correct , I would not have had room for the 31s if it was a top block Link to comment Share on other sites More sharing options...
'86 oopsie Posted December 10, 2009 Share Posted December 10, 2009 Correct me if I'm wrong, but isn't the lift from extensions on the bottom of the strut, between the strut and Knuckle? It works, but is different than most of the "conventional" tophat style blocks most lifts use. It allows for more tire height. Yeah, sorry I did'nt get into detail like I should have:-\ Link to comment Share on other sites More sharing options...
Phizinza Posted December 10, 2009 Author Share Posted December 10, 2009 I was planning on doing a strut insert mod to the struts any how and while I am there I can move, shrink, etc the coilovers to make room. Cheers for the heads up though! Link to comment Share on other sites More sharing options...
monstaru Posted December 31, 2009 Share Posted December 31, 2009 yes?you were saying? I was planning on doing a strut insert mod to the struts any how and while I am there I can move, shrink, etc the coilovers to make room. Cheers for the heads up though! Link to comment Share on other sites More sharing options...
Phizinza Posted December 31, 2009 Author Share Posted December 31, 2009 This is just for more travel and a lift for an old 83 wagon. But you can pretty much weld anything you want when the shocker is out of the strut so changing spring perches is no trouble. These inserts are 388mm long body opposed to the standard 360mm struts. And have about 200mm travel opposed to the 125mm standard 4WD struts come with. So all up great for a 2 to 3 inch body lift and offer 3" more travel. I did however find they were weaker then standard (bent them doing jumps in the race wagon) but for general off road use they would be fine. Also you can beef up the outside of the strut to increase strength so..... For some reason not all photos are showing up here, so click this link to see them http://img64.imageshack.us/g/10102009960800 Link to comment Share on other sites More sharing options...
monstaru Posted December 31, 2009 Share Posted December 31, 2009 right, i've made a strut too.... for ea series, but nor for ej series .... of which you speak the weight will be the issue cheers, rbain Link to comment Share on other sites More sharing options...
Phizinza Posted December 31, 2009 Author Share Posted December 31, 2009 weight? Link to comment Share on other sites More sharing options...
monstaru Posted December 31, 2009 Share Posted December 31, 2009 if those shockers, are to light and got bent before,you might oughtta look at another for the EJ ya know?cheers, brian weight? Link to comment Share on other sites More sharing options...
Phizinza Posted January 2, 2010 Author Share Posted January 2, 2010 With the EJ it would be easy enough to weld on extra reinforcing around the outside. The EA doesn't allow for this because the "slot in" type fitment. Link to comment Share on other sites More sharing options...
monstaru Posted January 2, 2010 Share Posted January 2, 2010 i thought you were talking about the shaft of the strut itself, not the outside .......cheers, brian Link to comment Share on other sites More sharing options...
Phizinza Posted January 2, 2010 Author Share Posted January 2, 2010 No, what bends is the strut at the bottom. In the EA, where it "slots in" to the knuckle it bends right at that mount. I'll have to go get a picture for you. Link to comment Share on other sites More sharing options...
