Squeaky mornings PS pump driving belt 02' Legacy GT
Squeaky sound from under the hood in the mornings, and mornings only. no cat, squirrel, or chipmunk jumping out... Rather, It seems to be the PS belt because when steering first time out of the driveway is when the screeching is the loudest. Goes away after warm up.
Yet to accurately measure the belt tension, but quick look didn't see anything too loose there.
Is it just a belt, or is PS pump going to die on me?
Is there a simple remedy to the noise? Soap on the belt?
Any hints on belt replacement job? Is belt expensive? I tried to search on-line, but only found an AC/alternator belt, which was about $12.
Thanks,
-Michael
dealer should sell both belts as a set. I've had the squeel in the mornings (winter only) for a couple years, I also have a Perrin crank pulley. I just think of it as a part of life. like when when a plane's tires hit the ground. could be PS pump bearing-but I doubt it.
