The above picture is for the 2001 and earlier. Starting in 2002, the PCV valve was moved to the OTHER end of that hose down in the engine block rear.
On the 2002 and newer, that picture is just an orifice where the upper end of the PCV valve attached to the throttle body. Follow that hose down and you will find yours.
Also note, it IS a different valve and part number from the one that was mounted on the throttle body as shown.
