Tobbe Posted November 15, 2009 Share Posted November 15, 2009 Hello. I have a 1987 Subaru Brat (European version) with an EA81 engine, caruburettor, breakerless ignition system with the ignitionmodule inside the dist. One day I strted my car as usually, got about 50 m when it suddenly stopped. It was just like somebody had turned a switch. I stood still for about 30 minutes, without any kind of lifesign from it. Then suddenly it strted again. I got about 500 m, when it just stopped again. After that it hasn't started again. There is no spark, and no signal from the ignition coil. I have replaced the; distributorcap, and rotor. I have also tried with another ignition coil and cable between the ignition coil and the distributor. I suspect that it could be the ignitionmodule, but I haven't found any way to test it. According to my Haynes manual the resistance can't be chekked on my type of system. I also have another weird problem, at least I think it is a problem. When I remove the fuse for the fuelpump and turn on the ignition, the pump starts, but with the fuse in place, the isn't a sound from the pump. Does anybody have an idea of how I can fix it, could the fuel and ignition problem be related? I am very grateful for any tip. /Tobbe Link to comment Share on other sites More sharing options...
GeneralDisorder Posted November 16, 2009 Share Posted November 16, 2009 If you have power at the coil (and it's good) and no spark from the distributor then your problem is very likely the ignition module. I would pick up a used distributor and give that a try. GD Link to comment Share on other sites More sharing options...
Tobbe Posted November 26, 2009 Author Share Posted November 26, 2009 Is ther any way to measure the ignitionmodule first, so that i really can see that it is broken before i look around for a used distributor. About my fuelproblem. Does anybody know how the fuelpump control unit work. Believe it is a relay of somekind that says cleaner cont on it. When I wire the fuelpump directly from the fuse to the pump it runs continuously, but with the correct wires connected it only runs for a short time when the fuse is removed. Electrical stuff is not my cup of tea so, any tip is welcome. If anybody has subarus original workshopmanual, i'd be gratefull if you could e-mail it to me. Link to comment Share on other sites More sharing options...
naru Posted November 27, 2009 Share Posted November 27, 2009 (edited) The fuel pump control unit needs to see ignition pulses in order for the pump to run more than a couple seconds.No pulses=no fuel pump. Your ignition module is likely fried.They are sometimes sensitive to high resistance in the ignition secondary circuit.Check for a bad plug/coil wire and extra wide spark plug gaps before replacing it. The modules are a little difficult to test. If you have a known good one,you can compare readings between terminals using the "diode test" function of a digital multimeter. Easier test is on the car. As long as you have 12 volts at coil - w/key on,wiring is intact,and a test light that does NOT flash when connected to coil - while cranking,the module is bad. Take the disty cap off and check for play in the shaft too. Service manual http://www.finleyweb.net/JonsStuff/SubaruDocumentation/tabid/54/Default.aspx Edited November 27, 2009 by naru Link to comment Share on other sites More sharing options...
edrach Posted November 27, 2009 Share Posted November 27, 2009 I agree that the ignition module is likely toast. Hopefully, you have the Hitachi distributor where the ig module is relatively easy to replace. If you have a wrecking yard nearby you can pull just the module and know how to re-install it in your car. Link to comment Share on other sites More sharing options...
Tobbe Posted January 20, 2010 Author Share Posted January 20, 2010 A new ignition module did the trick. Thank you for the tips. Link to comment Share on other sites More sharing options...
