Uberoo Posted November 16, 2009 Share Posted November 16, 2009 Hopefully in a couple of weeks I will be able to go up to pull and save and pickup parts for a 5 speed swap. From what I understand I will need: 5 speed DR transmission 5 speed linkages two piece driveshaft with carrier bearing EA82 flywheel EA82 clutch/PP Then for the install I just need to bash the tunnel(where?) and install the carrier bearing. Anyone have any pics of where to bash the tunnel for clearance?Also is there anything else I missed? Link to comment Share on other sites More sharing options...
Phizinza Posted November 16, 2009 Share Posted November 16, 2009 If you have an EA81 with a 225mm clutch already you can keep your flywheel and just put 4 to 6mm spacing washers between your starter motor and gearbox. Then just use the EA82 friction plate in the EA81 flywheel and pressure plate. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted November 16, 2009 Share Posted November 16, 2009 Phizinza said: Then just use the EA82 friction plate in the EA81 flywheel and pressure plate. Only the '85/'86 EA82 disc will fit in the EA81 PP opening. It has to have the small, round center spring section to fit. The '87+ discs have a sqaured-off spring section that doesn't fit at all. GD Link to comment Share on other sites More sharing options...
Phizinza Posted November 17, 2009 Share Posted November 17, 2009 that must be a US thing. I used am 88 disc... Link to comment Share on other sites More sharing options...
jrettenmayer Posted November 17, 2009 Share Posted November 17, 2009 If you want to make the trip over the mountains to Missoula, I have a 5 spd. DR trans, the flywheel, shifter linkages, and the driveshaft you are looking for in a parts car. Let me know if you're interested. Link to comment Share on other sites More sharing options...
bobjr94 Posted November 17, 2009 Share Posted November 17, 2009 Its a great swap, make your car seem as if it has alot more power, no more screaming up a hill at 4000rpm in 3rd or bogging down at 1500 in 4th. I only had to bump up the tunnel in 1 spot. http://www.cardomain.com/ride/2619108 Link to comment Share on other sites More sharing options...
Mr. Brat Posted November 19, 2009 Share Posted November 19, 2009 You will need to either make a set of mounts or cut the ea81 and ea82 mounts apart and reweld them together. Also may need to grind down the lower part of the engine block where the inspection plate bolts up to. Link to comment Share on other sites More sharing options...
Uberoo Posted November 19, 2009 Author Share Posted November 19, 2009 Eventually I plan to put an EJ the car.So would I prefer that some of the mods mesh well with each other.So I was thinking of useing the EA82 clutch/PP/disk and flywheel. However I have found out that the bolt holes on the EA82 flywheel are slightly larger than the bolts for the EA81.What can be done there to make sure they are tight? Link to comment Share on other sites More sharing options...
GeneralDisorder Posted November 20, 2009 Share Posted November 20, 2009 Nothing need be done about it. Eyeball the bolts to the center of the holes and lock them down. Use blue loctite. The crank and flywheel are C flanged for centering. The holes being a bit large will not affect it in the least. GD Link to comment Share on other sites More sharing options...
Mr. Brat Posted November 20, 2009 Share Posted November 20, 2009 I have a d/r 5 spd in my brat and didn't have any problem with the larger holes in the flywheel. Link to comment Share on other sites More sharing options...
Gloyale Posted November 25, 2009 Share Posted November 25, 2009 GeneralDisorder said: Only the '85/'86 EA82 disc will fit in the EA81 PP opening. It has to have the small, round center spring section to fit. The '87+ discs have a sqaured-off spring section that doesn't fit at all. GD The EA82 presusre plate bolts right onto the EA81 Flywheeel. Keep you're EA81 Flywheel and use EA82 PP and Disc. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted November 26, 2009 Share Posted November 26, 2009 Gloyale said: The EA82 presusre plate bolts right onto the EA81 Flywheeel. Keep you're EA81 Flywheel and use EA82 PP and Disc. That's true but the step on the flywheel is different so you have to have it machined to EA82 specs or there is a possibility that it won't grab very well. GD Link to comment Share on other sites More sharing options...
