2001 2.5RS coupe Driver Rear tire off camber??
So a buddy of mine slid off into the dusty dirtness on one of our highways, and f'd up his rear drivers side tire. when sitting behind the car, it looks like the tires go
\----| <---so his driver rear tire is tweaked. Reading up, (and not
having access to the car yet so i havent pulled the tire) it seems there isn't any camber adjustment on the 01 impreza coupe. Is this true? if so, what piece is most likely bent to make the camber so far off? any ideas would be great before i get his tire off. the tire seems like its not pushed forward or back, just bent...
thanks!!
Obviously as mentioned the first thing to do is inspect and see what if anything is bent or damaged..the camber adjustment..well you can loosen the strut bolts on the hub and move the hub a tad to give you a little more positive or negative camber....
