Caramanos2000 Posted November 19, 2009 Share Posted November 19, 2009 When it rains I get water showering my feet coming from the pedal area. Its a 87 GL Wagon. You good folks have any ideas? Link to comment Share on other sites More sharing options...
TheLoyale Posted November 19, 2009 Share Posted November 19, 2009 Hmm, could the bottem of the windsheild seal be leaking and running under the dash and hitting your feet area? That or the firewall some how leaks? :-\ -Tom Link to comment Share on other sites More sharing options...
kelsomcgath Posted November 19, 2009 Share Posted November 19, 2009 I've had leaks now on both of my subarus when i first buy them... both coming from the windshield.. both leaked down to the floor. Check all around the windshield, hopefully that's all it is.. easy fix. -kelsey Link to comment Share on other sites More sharing options...
crazily Posted November 19, 2009 Share Posted November 19, 2009 also check the outside where the windscreen is next to the wipers, it might be leaking through there. Link to comment Share on other sites More sharing options...
andrewmiller Posted November 19, 2009 Share Posted November 19, 2009 nothing a little silicone on the windshield wont fix Link to comment Share on other sites More sharing options...
Caramanos2000 Posted November 19, 2009 Author Share Posted November 19, 2009 also check the outside where the windscreen is next to the wipers, it might be leaking through there. I checked this area, no dirt no nothing not even rust... The windshield is the likely culprit as the rubber seal is starting to buldge outwards. Link to comment Share on other sites More sharing options...
TheLoyale Posted November 19, 2009 Share Posted November 19, 2009 Well if thats the case, just get some clear all weather Silicone, pull out the rubber a little, pump some into the crevus and push the rubber back in (Wipe away exccess) -Tom Link to comment Share on other sites More sharing options...
torxxx Posted November 19, 2009 Share Posted November 19, 2009 look at the spot where ur drivers side wiper bolts down. There is a pocket there with a lil rubber plug in the bottom of the pocket. I dont know why they put these there but I've lost both of them in my car and when ever it rain my wiring harness would be soaking wet. Clean it up real good, spray it off with brake clean (the green can - non chlorinated) and then fill the hole with The right stuff, or RTV. I prefer the right stuff because RTV doesnt harden up Link to comment Share on other sites More sharing options...
