Introduction for a long time member
Dropped the gas tank off at a rad shop today to see if they can repair it. I'd prefer to go with a repaired tank rather than a used tank that could start leaking again in 6 months...
As for the rust, we were planning on attacking the surface rust with a wire wheel, rust converter and por-15
Not sure about what to do with the rust on the underbody, I'm a little nervous about taking a grinder to it, never had to do any serious rust repair before. Maybe I'll see if one of our toyota buddies can give us a hand :banana:
Welcome! I also have a Turbo brat. Mine sits far too much. I did a 4spd manual swap otherwise mine is stock.
It will say on the intake that its a Turbo and of course have the turbocharger on the passenger side of the engine compartment on the back beside the spare tire. Its a pretty small turbocharger though.
In order to do the d/r swap, either 4 or 5 speed, what would be the ideal donor car? We also want to do the rear disc swap, so it should have those too if possible!
You'll need to be looking at a turbo EA82 car for the rear discs.
Then you'll need a carb or SPFI EA82 wagon for your 5sp d/r transmission,
driveshaft, flywheel, clutch and crossmember.
But I highly recommend buying the clutch set new, and if possible, to make it
easier, buy Jerry's (BRATSRUS) 5 speed kit.
Or, if you want less hassle, go for the 4sp d/r and its a direct bolt in.
You just need the flywheel and clutch set.
And it'll be out of another 2nd gen BRAT, a hatchback (not 3 door coupe) or
pre-1984 wagon or sedan (very rare to find a d/r sedan, if you do, buy it!!!).
Twitch
  • 3 weeks later...
Would an 87 Turbo RX make a good donor car? It's got a 5speed D/R
Heck yes!
If its an RX that means its turbo, so you're gonna have to swap out the diff
stubs, so you can put 23 spline axles in place of 25 spline ones (which are too
long for your car)
You can ask just about any off roader how to pull diff stubs.
They should know.
Chances are it's got the full time 4wd d/r tranny if its an RX, so you're in luck
there (they're pretty rare), plus you'll be able to grab the disc brakes!
But you'll need the diff as well, as they have a 3.7 diff ratio, rather than a 3.9
like your BRAT.
You'll need to swap the stubs on the diff as well.
Other than the bit of work you're gonna have to put into it, great find!
Make sure you don't damage any of the plastic/fiberglass ground effects on
that RX, they're pretty rare as well and many members search for them
regularly.
Twitch
It'll make a good parts car. 3.7/1 final drive is a step backwards. You can sell the trans, body kit, interior and other tid bits to finance a 5sp D/R with a 3.9 final drive. You can do a diff swap to get the LSD in a 3.9 rear diff.
