derby Posted November 20, 2009 Share Posted November 20, 2009 Early this summer, bought this car 93 impreza drove it just a few times noticed temp never got to half way on gauge. now that it almost winter,the temp gauge never starts to raise & i have no heat? Bad mixture a coolant? I havent checked to see if someone took out the thermostast. Any suggestions would be appreciated. Link to comment Share on other sites More sharing options...
idosubaru Posted November 20, 2009 Share Posted November 20, 2009 sounds like someone removed the thermostat or it's stuck. get a Subaru thermostat, that could be the problem, someone previously replaced it with an aftermarket which look like tin toys next to the Subaru units. aftermarket tstats are known to cause issues sometimes. but even if it is Subaru it could be 15+ years old. Link to comment Share on other sites More sharing options...
nipper Posted November 20, 2009 Share Posted November 20, 2009 And a new cap. nipper Link to comment Share on other sites More sharing options...
Rooster2 Posted November 21, 2009 Share Posted November 21, 2009 Prolly a good idea to flush out the cooling system, then install a new thermostat, along with a new radiator cap, and fresh antifreeze. Link to comment Share on other sites More sharing options...
Durania Posted November 21, 2009 Share Posted November 21, 2009 My vote goes for t-stat was well. Make sure and get the gasket that goes with the Subaru t-stat. Link to comment Share on other sites More sharing options...
derby Posted December 8, 2009 Author Share Posted December 8, 2009 Thanks for the replies, I'm going to start with t-stat .I'll post results. Thanks Derby Link to comment Share on other sites More sharing options...
AlpineRaven Posted December 8, 2009 Share Posted December 8, 2009 if in that case above does not work, it could be the sensor that has gone bad. Its located under the manifold on right side under the throttle body. Cheers AP Link to comment Share on other sites More sharing options...
derby Posted December 11, 2009 Author Share Posted December 11, 2009 alright, replaced thermostat & gasket,new anti freeze 50/50mix ,took about 15 min idling the temp gauge finally registered on the gauge half way,still no heat. with the rad cap off i never really see the water rushing while recirculating,bad water pump? but that would cause over heating? if i rev the engine i get a little spurt of heat but its quick. whats the sensor i should check,Thanks ric Link to comment Share on other sites More sharing options...
AlpineRaven Posted December 11, 2009 Share Posted December 11, 2009 derby said: alright, replaced thermostat & gasket,new anti freeze 50/50mix ,took about 15 min idling the temp gauge finally registered on the gauge half way,still no heat. with the rad cap off i never really see the water rushing while recirculating,bad water pump? but that would cause over heating? if i rev the engine i get a little spurt of heat but its quick. whats the sensor i should check,Thanks ric When was the water pump last replaced? Cheers AP Link to comment Share on other sites More sharing options...
nipper Posted December 11, 2009 Share Posted December 11, 2009 Clogged radiator? Link to comment Share on other sites More sharing options...
Suzam Posted December 12, 2009 Share Posted December 12, 2009 Subaru has a specific way of refilling the coolant system. Did you burp? Link to comment Share on other sites More sharing options...
98obster Posted December 12, 2009 Share Posted December 12, 2009 it's a pain but I put the front on jack stands and turn the controls to full heat until the t-stat opens and see the fluid running through the radiator with the cap off. Link to comment Share on other sites More sharing options...
Rooster2 Posted December 12, 2009 Share Posted December 12, 2009 With the motor warmed up, and your heater controls put on high, put your hands around the heater hoses near the firewall Do both hoses feel warm? If not, the small radiator (can't think of it's proper name) inside the firewall is partially plugged up, and not allowing proper flow of the coolant, so heat output is poor. You may have an air bubble in your cooling system after changing antifreeze. If so, you need to "burp" out the bubble to give proper coolant flow through the cooling system. This too, could cause poor heating. Link to comment Share on other sites More sharing options...
