rendoll911 Posted November 20, 2009 Share Posted November 20, 2009 hey guys, I am just wondering how long it will take for a new rotor to show signs of contact with the brake pads? I am asking this because I put new rear pads and rotors on my 99 legacy about a week ago, but the rotors only show wear on the inner most part of the rotor (closest to the center of rotor) Could it be that not all the pad is touching the rotor? This was my first brake job so I'm thinking i may have messed up with something. Also i used Advanced auto rotors and pads. This was a hell of first brake job seeing how I snapped one of the bolts holding the hold rotors on. Took 4 hours to drill it out and i rushed to get everything back together so now im worried! any ideas? Link to comment Share on other sites More sharing options...
Fairtax4me Posted November 20, 2009 Share Posted November 20, 2009 It should be an even wear pattern and should be evident within 20 miles or so of driving. Uneven wear would indicate the pad is installed incorrectly or the slide pins are seized preventing the caliper from moving to balance braking force on both sides of the rotor the way it's supposed to. Link to comment Share on other sites More sharing options...
rendoll911 Posted November 20, 2009 Author Share Posted November 20, 2009 a seized slide pin would cause the part of the rotor closest to the hub to wear? Link to comment Share on other sites More sharing options...
Fairtax4me Posted November 20, 2009 Share Posted November 20, 2009 Yes. The piston pushes on the inside pad. If the slide pins are seized or sticking they will act as a fulcrum or hinge and push the outer pad towards the hub. Causing only the inner edge of the pad to make contact with the rotor. There's not a 100% guarantee that that's the problem, but it's pretty common on old calipers for the pins to "stick" due to rust or corrosion. Link to comment Share on other sites More sharing options...
