Niku-Sama Posted November 22, 2009 Share Posted November 22, 2009 i think its ATF, short story is when the car isnt quite warmed up it leaves little trails behind. i still need to do the valve cover but i dont think it would leave little trails like that. the transmission is getting low on ATF every now and again, takes about 3k miles before any noticable level change but i cant find where its leaking any atf. the PCV system is cleared and workin right including that one vent line that goes to the top of the transmission, are there other vents though? i thought there were. ideas? 4EAT trans oh one time it burped a bit of atf in the driveway but we again still could not find where it came from Link to comment Share on other sites More sharing options...
Turbone Posted November 22, 2009 Share Posted November 22, 2009 Did you check all the coolant line connections? 2 at the tranny and 2 at the radiator. Also might look underneath while its running and look for drips. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted November 22, 2009 Share Posted November 22, 2009 Maybe comming out of the rear driveshaft seal? Those aren't an uncommon leak point and they are easily replaced. Only get those from the dealer as I've had friends that replaced them with NAPA seals only to have them leak again in a week or two. Thinking maybe the ATF is sloshing rearward when you take off causing it to run out of the rear output...... just a guess. GD Link to comment Share on other sites More sharing options...
Niku-Sama Posted November 25, 2009 Author Share Posted November 25, 2009 hmm well the lines and everything seem good so mabe it is just slosh Link to comment Share on other sites More sharing options...
