()__1337_CRAYOLA__()> Posted November 23, 2009 Share Posted November 23, 2009 I was driving around Seattle all day today and i was getting this thumping from the front right of my car. It would only do it at low speeds while braking (clutch pedal in),compression braking and slow coasting(no it wasnt because of the road ). I inspected everything on the front end i could laying on the side of the road but everything looks to be in order. i went to a friends house and came out and drove home and it was gone, although it was doing it last time i was in Seattle and as soon as i left i never thought about it again till today. and i also picked up a rattling from the passenger rear at 55-65 MPH today as well. BTW 1983 Subaru GL 4WD with 5 speed conversion and SJR 4" lift. Link to comment Share on other sites More sharing options...
Dirk Posted November 23, 2009 Share Posted November 23, 2009 When did you last replace the brake pads? Link to comment Share on other sites More sharing options...
()__1337_CRAYOLA__()> Posted November 23, 2009 Author Share Posted November 23, 2009 i inspected not to long ago while putting my bigger tires on and they were about 3/4 life left Link to comment Share on other sites More sharing options...
Dirk Posted November 24, 2009 Share Posted November 24, 2009 Could be that a brake pad has partially broken. Or perhaps you have a slight buckle in your disc. Though I understand that it takes a fair amount of heat to do this. Have the brakes had a particularly hard work out lately? Been up and down any mountains? Link to comment Share on other sites More sharing options...
()__1337_CRAYOLA__()> Posted November 25, 2009 Author Share Posted November 25, 2009 well turns out when i rebooted my front axle i didn't get the nut tight enough.... tightened it down a little more today and all is well.. although i see wheel bearings in my future... Link to comment Share on other sites More sharing options...
Yo'J Posted November 25, 2009 Share Posted November 25, 2009 200ftlbs whats this "a little more" stuff. Link to comment Share on other sites More sharing options...
()__1337_CRAYOLA__()> Posted November 25, 2009 Author Share Posted November 25, 2009 yeah i figured that out i got a nice bar and put about that much on it Link to comment Share on other sites More sharing options...
Dirk Posted November 26, 2009 Share Posted November 26, 2009 Nice one! Generally the length of the correct size spanner should torque things up about right depending on how big your bicepts are. Link to comment Share on other sites More sharing options...
