Another Brat (almost) on the road
Some of you may recognize it, it used to belong to Qman. He built it and used it for Rally X for a season, winning his class (truck).
A little about the car....
EA81 with EA71 pistons
Hotter cams. Qman may have to give info on these, I dont recall.
Recurved disty.
Weber carb.
Catless exhaust.
GL-10 rear sway bar and disc brakes.
This has been sitting for a while. I purchased it about a year ago and have just recently started putting new HG's and cleaning things up on the engine.
We knew it had a internal water leak and a seized WP, but we didnt know how bad it was.
Oh, it was bad.........real bad.
Pics are in order of work done.
Prior to engine removal.
Engine out.
I took the heads in and had them milled and a broken intake bolt removed :rolleyes:
Then I started cleaning.
*WARNING*
These pics are not for the squeamish. If you have a weak stomach, scroll to the bottom.
Half the block cleaned.
I have never seen a mix of oil and water like this, it was like chocolate pudding. And it was everywhere.
Oil pan full of pudding......yummmm.
Oil filter was almost full also.
Once I had the inside of the oilpan clean, I had this to work on.
The valve covers where just as messy inside and needed lovin on the outside.
Yes, even the carb got slimed.
I had to remove the top and clean the bowl, jets and internals.
Ok, enough of the gross stuff. Its time for pretty.
I dont think I need captions for all this.
I used a wire wheel on my Makita and then clearcoated it all, it will be easy to keep clean now.
I still have work to do in the engine bay. But the engine is in and running (like crap). I need tune up stuff and need to burn the old gas off. I also need to replace the seats. These were setup for Qman, who happens to be quite a bit taller than me. And it needs a good cleaning/clay bar along with lots of trim repainting.
Heres a few pics of the Brat. I mounted my Hankook iPikes with pugs today.
Rob,
STELLAR job on the engine! Lookin good. :cool:
Do you have any pics of the case apart and going back together?
Damn I love those motors!
I didnt split the case, Qman did and that was about 5yrs ago.
Awww now i dont feel original, thats the paint scheme i was gonna use on my 14 aluminum pugs. What size tires u running.
They are 185/70/14's
I painted these before last winter and ran them on my RX.
