High Oil Pressure
I have this issue but the gauge stays up against redline, hot or cold. I swapped the PCV valve but it had no effect.
To be honest, I never expected to have a high oil pressure issue. I have owned brats for over 20 years and have never run into this. Is this bad for the engine? Any ideas for a fix?
btw: I sure admire you guys. I have worked, swapped about everything that can go wrong over the years and you guys put me to shame. Thanks for sharing your vast experience. I love these old cars and more than once you have help me keep them on the road.
It sounds like a bad sender, the wire from the sender is grounded, or the gauge is done.
Advice for both of you: check it with a mech. gauge.
