flyer23 Posted November 24, 2009 Share Posted November 24, 2009 I have this code and have replaced the purge valve already with a new one. Same code. Has anyone else had this code and an area that might be leaking from. My car is a 1995 Legacy L automatic with AWD. I pray I don't have to remove the fuel tank due to RUST...LOL. Any advice would be great. I don't have access to a smoke machine otherwise it would be easier to find. Thanks in advance. Link to comment Share on other sites More sharing options...
Fairtax4me Posted November 25, 2009 Share Posted November 25, 2009 Assuming you don't have any other codes. The hose for the evap probably has a split or hole in it somewhere along the line. You can have someone blow into the evap hose under the hood while you listen underneath the car for air movement. There are a few other valves, one near the fuel tank, and one near the evap canister at the back of the car. Check both of those for operation as well. The whole evap system is complicated as hell. Good luck finding the leak. Link to comment Share on other sites More sharing options...
johnceggleston Posted November 25, 2009 Share Posted November 25, 2009 is this the code you get when the gas tank filler neck has holes rusted through?? that's pretty common in some parts of the country, the rust belt. Link to comment Share on other sites More sharing options...
flyer23 Posted November 25, 2009 Author Share Posted November 25, 2009 is this the code you get when the gas tank filler neck has holes rusted through?? that's pretty common in some parts of the country, the rust belt. The filler neck was rusted out, but I replaced it with a new one and reset the light. The P0441 code keeps coming back so now I know where to start looking. Thanks for the info. Link to comment Share on other sites More sharing options...
Fairtax4me Posted November 25, 2009 Share Posted November 25, 2009 is this the code you get when the gas tank filler neck has holes rusted through?? that's pretty common in some parts of the country, the rust belt. happy happy joy joy! I get to look forward to this! I'm surprised mine isn't leaking yet. Link to comment Share on other sites More sharing options...
