'91 EA82 Carby Gasket Choice
Hi,
I am about to strip down my '91 L Series EA82 n/a Carb engine as I have a fair bit of oil in the coolant.
I have been quoted over $300 USD for a head gasket kit here in Australia which is ****** ridiculous. I normally buy a lot of parts from the US for a couple of F150's I have and that company have listed a Fel-pro Gasket Kit HS 9392 PT-2 at a much more reasonble price. However, it only mentions that it fits the Spfi version.
Does anyone have any ideas on whether the Fel-Pro will fit and/or ideas as to who might help.
Thanks alot.
Rock Auto, I had to enter for a 1985 GL, VIN 5. This is the kit you'd need tho.
Doug
FEL-PRO Part # HS9392PT2 MoreInfo.gif {HEAD SETS (HS) are used for upper engine repair only, typically on a valve grind.}
SOHC engine; PermaDry® molded rubber valve cover gskts. incl.; Premium valve stem seals incl.HS9392PT-2_TOP.jpg
$113.89$0.00$113.89
