NEED ASAP FSM for RX trans with locking center diff
For the case halves it's going to call for a variant of 3-bond which you probably won't be able to source. It's a japanese brand of RTV but for flanged mating surfaces like these I prefer an anerobic sealant such as loctite 515 or 518.
What do you need torque specs for? I don't have an FSM for the RX tranny specifically but I do have some that cover various transaxles. There isn't a lot inside these that requires super exact torque - no mechanical locks or gasket crush that I've seen. You should be able to use a standard torque table for the size/pitch of the threads you are working with. Any machinists handbook will have these.
http://68.178.49.203/jon/SubaruEA82-ServiceManualPart1.pdf
http://68.178.49.203/jon/SubaruEA82-ServiceManualPart2.pdf
Part 1 & 2 of the EA82 FSM. I believe the breakdown on a FT4WD 5spd is in there somewhere.
Thanks Brian, except that whoever scanned those skipped over Section 3 (the transmission section) and went straight to Section 6. FTMFL.
-Bill
