gpb9900 Posted November 27, 2009 Share Posted November 27, 2009 The hot wire from the battery is bad somewhere. Simple solution: I'm running a new hot from the battery to the fuse-box. I previously called a Subaru dealership looking for a directional/hazard module thinking that was the culprit. Allegedly only 3 left in the entire country from Subaru! Link to comment Share on other sites More sharing options...
robm Posted November 27, 2009 Share Posted November 27, 2009 This sounds a lot like it might be a bad fusible link. Check it again, try a new one. If the link is sound, and the conductor is bad, then run the new conductor from the link, not directly from the battery. The link is there for overcurrent protection, it is safer to not bypass it. Link to comment Share on other sites More sharing options...
gpb9900 Posted November 27, 2009 Author Share Posted November 27, 2009 Where is the fusible link? I went with the simplest approach because I immediately got frustrated with the massive wire bundle and my inability to follow where the wire I needed went. This is the most extensive work I've ever done on a vehicle myself so much of this is all new to me. Thanks for the advice, BTW. Link to comment Share on other sites More sharing options...
Cougar Posted November 28, 2009 Share Posted November 28, 2009 The links are in a plastic case. It may be mounted on the coolant reservoir. Link to comment Share on other sites More sharing options...
akc Posted November 29, 2009 Share Posted November 29, 2009 the fusable links are in a little black box the top states something like black, green, red with numbers. if you open it you sound see 4 colored wires. you can test the link by running a wire from one side to the other (do not leave it that way replace the link as it is a fuse) Link to comment Share on other sites More sharing options...
