Where are the headlight relays located?
1991 Justy... low beams only operate intermittently, and I suspect the low beam relay is sticking sometimes. Sometimes turning the headlights off then back on will restore them...sometimes not. They usually turn on when I first start the car, but not always, and often they do not come back on after switching to hi beams. Hi beams always work fine. I don't even know where to look for the relay though... I've tried a few under the hood, and they weren't it. My old '82 wagon had the exact same problem, and I never tracked it down...rust ate the rest of it about the same time :(
With it getting dark earlier now, I have to use the lights, and part of my commute is in traffic where using hi beams is out..... the auxiliary driving lights work okay in a pinch but really aren't the best.
Z
