Danbob99 Posted December 4, 2009 Share Posted December 4, 2009 Hey guys, I've searched extensively, but not been able to find any affirmitive results on this. I recently swapped over some Impreza knuckles, brakes, hubs etc. onto my 89 GL, wich I had previoulsy done a 5-lug swap on, using XT6 front end stuff. After getting it all assembled my toe is waaay out. So, I cranked it in, but at the limit of adjustment, i've still got another 1/2" to go on either side. Thus, I need to find some shorter outer Tie-Rod ends. Whats in there now i'm pretty sure are XT6 ends wich measure 6" exactly from the outer end of the ball joint to the inner end, not including the stop nut. Any one know which ends might be shorter? Mind making a few quick measurments for me? Thanks! Dan Link to comment Share on other sites More sharing options...
Yo'J Posted December 4, 2009 Share Posted December 4, 2009 ea81 4 5/8ths" 90 leg 5 1/2" Measured to the center of the joint. Link to comment Share on other sites More sharing options...
Danbob99 Posted December 4, 2009 Author Share Posted December 4, 2009 Excellent. EA81 Tie Rod end it is. I thank you for your quick response. Dan Link to comment Share on other sites More sharing options...
suberdave Posted December 5, 2009 Share Posted December 5, 2009 i had the same problem... i just ran a die up the inner tierod. then cut it an inch shorter... cheeper than buying mor parts. Link to comment Share on other sites More sharing options...
