hatchsub Posted December 4, 2009 Share Posted December 4, 2009 A buddy of mine just found a 91 turbo leg in the junkyard near us. Its complete with a 5 speed and the Ej22T and all. First off i know this is an uncommon car. How much does the motor go for in the market? And the transmission? What (if anything) should i pull. I was debating pulling the entire motor and tranny as a whole...possibly the rear diff (lsd?). Let me know. Quote Link to comment Share on other sites More sharing options...
subaru360 Posted December 4, 2009 Share Posted December 4, 2009 You can get $500-600 for the block. The rest of the engine isn't worth much. The trans isn't worth a whole lot, it's pull clutch like a wrx, but has the older style narrow gears old synchros. The rear lsd might be worth a few hundred if it's not the one with the old style axles, that one doesn't work in much but old legacys. Not all T legs have LSD. Quote Link to comment Share on other sites More sharing options...
hatchsub Posted December 4, 2009 Author Share Posted December 4, 2009 Since its a 91 i would assume its the older style dif? Yea as u can see my knowledge of newer subarus is lacking. At least this gives me something to go by. Quote Link to comment Share on other sites More sharing options...
erik litchy Posted December 4, 2009 Share Posted December 4, 2009 this car is very rare. yes the engine is good, but the heads dont flow as well as the newer models so they arent worth as much as the block. Quote Link to comment Share on other sites More sharing options...
The Beast I Drive Posted December 4, 2009 Share Posted December 4, 2009 EJ22T is a closed-deck block and quite desirable, that block alone could fetch a pretty penny. Sell the engine, trans, and rear LSD if it has one as a whole and you could probably get 1000+ for it from the right buyer. -Bill Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 4, 2009 Share Posted December 4, 2009 It will have a VLSD rear - only '91's came with them. The axle issue can be overcome simply by installing the '91 axles or DOJ cups into whatever car you are putting the diff into. It also will have an oil cooler between the pump and the filter which is nice to grab. The up-pipe in the exhaust is the same part as used on the STi's. It's catless so also desireable. If you pull the block, inspect it carefully. The old block that came from my car had melted part of the cylinder liner and was pretty chewed on the bottom end. I still traded it for a $350 turbo for my new engine though. The transmission isn't wanted - as noted they are weaker than the WRX tranny's which pretty much bolt in place for them anyway. GD Quote Link to comment Share on other sites More sharing options...
hatchsub Posted December 7, 2009 Author Share Posted December 7, 2009 Well so much for that idea. They want way too much for the block to make it reasonable for me to pull it since i probably wouldnt be using it anyways. Oh well. If i was actually going to use it myself then it would be a deal but i was just going to pull it and resell it. Cant justify all day outside in the cold pulling a motor that may or may not be good. Quote Link to comment Share on other sites More sharing options...
