86 Hatchback Clutch Question
Jibs
I tried searching, but between the dialup service and the wildcard issue its easier to ask. Im replacing the trans in my 86 hatch with one from an 82 wagon. The trans on the wagon has the smaller clutch and flywheel. The splines on the disc match up between the two but I'm worried on the size of the flywheel fitting the 82 trans, is it possible to use the bigger clutch on the earlier trans? Thanks.
