skibumm Posted December 6, 2009 Share Posted December 6, 2009 When I replaced my alternator a few days ago, I noticed allot of red dust under the AC compressor shield and on the compressor itself. Is this a sign of a bad bearing? Link to comment Share on other sites More sharing options...
john in KY Posted December 6, 2009 Share Posted December 6, 2009 Red dust probably came from the failing alternator. Link to comment Share on other sites More sharing options...
Scoobywagon Posted December 6, 2009 Share Posted December 6, 2009 The red dust is the same red dust that you see around your brakes and such. It is the result of the proper function of the clutch and the wear of the friction materials in the compressor clutch. Don't worry about it. Eventually the clutch will fail with the loss of enough friction material. But you aren't seeing anything unusual or worrisome. Link to comment Share on other sites More sharing options...
skibumm Posted December 6, 2009 Author Share Posted December 6, 2009 john in KY said: Red dust probably came from the failing alternator. It wasnt on the alternator or its shield, just the compressor sheild. Link to comment Share on other sites More sharing options...
skibumm Posted December 6, 2009 Author Share Posted December 6, 2009 Scoobywagon said: But you aren't seeing anything unusual or worrisome. Thanks Link to comment Share on other sites More sharing options...
CNY_Dave Posted December 7, 2009 Share Posted December 7, 2009 Lotsa red dust under mine on my '03, and even a good bit on my wife's '05 forester with about 45Kmiles. Dave Link to comment Share on other sites More sharing options...
erik litchy Posted December 7, 2009 Share Posted December 7, 2009 maybe the ac clutch? Link to comment Share on other sites More sharing options...
Scoobywagon Posted December 8, 2009 Share Posted December 8, 2009 erik litchy said: maybe the ac clutch? Yes, I believe that's exactly what I said. Link to comment Share on other sites More sharing options...
AlpineRaven Posted December 8, 2009 Share Posted December 8, 2009 it could be rusty, hence bad bearings still being used produces red dust (rust). Cheers AP Link to comment Share on other sites More sharing options...
