Suby gurus I have a turbo question
I'm looking at a vf10/11 from a legacy turbo as a possible upgrade for my stock vf7. here's my question... will the vf10/11 bolt in place of the vf7 or am I better off just converting to the TD04L? I'm not looking for huge power just less heat at the same boost levels. I already have an intercooler and d/v installed on the car and I am planning a set of 280xz-t injectors in the very near future.
The VF11 is a better size for the EA82T though so you should consider that as well. And you can rotate the compressor outlet on the VF11 if you want to.
They are both good choices - just depends on where you want the power to come on. The TD04 is going to be a bit higher than the VF11 just due to the size differences.
I'm going to the TD05-16G on my 22T - the VF11 is just too small - always was undersized for my engine. Just about perfect for the 1.8 though I should think. 10 psi is all you want anyway......
