Speedwagon Posted December 7, 2009 Share Posted December 7, 2009 Anyone have the list of what all the wires on the brown plug(85 Brat) do? So far, I've got a confirmed ACC, ground, and lights/dimmer. But there's a yellow wire that I couldn't determine, and a red/green(I think) that was very low voltage(test light barely came on). Any idea what these do? Link to comment Share on other sites More sharing options...
rxleone Posted December 7, 2009 Share Posted December 7, 2009 When I did it I couldn't find a permanent memory cable, so I just undid the fuse box under the dash, found a wire that was on permanently (turned out to be the door light) and wired that sucker up. Perhaps you could do the same on a accessory wire? The low voltage wire sounds suspect. Have you put an actual multimeter onto it and checked the current? Could pay to. John Link to comment Share on other sites More sharing options...
Speedwagon Posted December 7, 2009 Author Share Posted December 7, 2009 I have a multimeter, but I was doing this in the dark, in 10F weather. So I will wait to probe it with the multimeter until warmer, daylights hours. And the memory wire is basically why I am asking. If one of these wires are unused for this application, I can rewire it, and maintain a disconnectable harness for easy removal. Link to comment Share on other sites More sharing options...
rxleone Posted December 7, 2009 Share Posted December 7, 2009 I would undo my dash and show you how I wired mine, but the bloody thing is such a birds nest you'd probably cringe at the sight of it. Note to self: Rewire the whole bloody thing. Probably near a damn fire hazard, to be honest. The memory cable was quite easy; I'm not too sure if the fuse panel is on the drivers side or not, but basically I just undid all the panelling around it,unbolted the fusebox, found the open-door light fuse, took out the terminal holding it in there and wired it in. I was in a bit of a rush at the time though, so maybe one of the other guys could tell you whether its a good thing to do or not. It's been like that in mine for a good few months now with no problems. Link to comment Share on other sites More sharing options...
Speedwagon Posted December 7, 2009 Author Share Posted December 7, 2009 I know where to pull a wire from, my goal here is to make it as stock looking as possible for the wiring. So I don't have extra wires all over. Link to comment Share on other sites More sharing options...
87glsubie Posted December 7, 2009 Share Posted December 7, 2009 from all the stereos ive done. black= ground blue= remote accessory / light dimmer could be anything and yellow is usually the power wire. red is your memory i believe so all ur settings stay set Link to comment Share on other sites More sharing options...
quartus Posted December 7, 2009 Share Posted December 7, 2009 Speedwagon said: yellow wire and a red/green(I think) Any idea what these do? Yellow wire is "always on" 12v (for memory retention) and Red is ACC controlled power , i.e. ig switch must be turned on for 12v to be present. Link to comment Share on other sites More sharing options...
87glsubie Posted December 7, 2009 Share Posted December 7, 2009 damn. i had em backwards hah Link to comment Share on other sites More sharing options...
Speedwagon Posted December 7, 2009 Author Share Posted December 7, 2009 quartus said: Yellow wire is "always on" 12v (for memory retention) and Red is ACC controlled power , i.e. ig switch must be turned on for 12v to be present. Are we talking about the same vehicle? Every thread I've read on here says there is no constant power on an EA81, at the stereo. And the yellow didn't have power on it either. The red is the ACC, not the red/green. The Red/green is the one in question. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 7, 2009 Share Posted December 7, 2009 Correct - EA81's do not have a constant power source to the radio. Typically it's tapped from the ignition harness for most stereo installs though I like to use the clock power personally. GD Link to comment Share on other sites More sharing options...
Speedwagon Posted December 7, 2009 Author Share Posted December 7, 2009 GeneralDisorder said: Correct - EA81's do not have a constant power source to the radio. Typically it's tapped from the ignition harness for most stereo installs though I like to use the clock power personally. GD The clock is what I was planning to tap. Do you know off hand which wire that is, and the best place to get to it? And I guess no one knows what this yellow wire is for then? Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 7, 2009 Share Posted December 7, 2009 There is a bullet connector under the dash area that was used to disconnect the clock power for shipping from japan. I tap into that. It's just a single wire that feeds the clock memory power. I can't remember the wire color but just take a look on the passenger side of the column and it should be there. I can't recall what the yellow wire does. I might have it in my FSM - I'll try to take a look today. GD Link to comment Share on other sites More sharing options...
()__1337_CRAYOLA__()> Posted December 7, 2009 Share Posted December 7, 2009 just take the wire cram it into one of the fuse spots then cram the fuse back in and your done constant 12v Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 7, 2009 Share Posted December 7, 2009 Quote just take the wire cram it into one of the fuse spots then cram the fuse back in and your done constant 12v And when your $hitbox burns to the ground because of your hokey wireing practices and all the other piss-poor wrenching that you have done - don't blame this board - please go directly to Crayola's house and ask his mom if he can come out to play GD Link to comment Share on other sites More sharing options...
Speedwagon Posted December 7, 2009 Author Share Posted December 7, 2009 I found a good constant power... then I verified it was the clock circuit when I accidentally grounded it. It was a green connecter, driver's side under the dash, not connected to anything. Had a black and yellow wire in it, with the black(white stripe I think) being the constant. Someone had previously tapped it, though there was no wire on it when I got the car. So all is good now, but I'm still curious as to what the other wires in the brown connector for the stereo are. Link to comment Share on other sites More sharing options...
()__1337_CRAYOLA__()> Posted December 9, 2009 Share Posted December 9, 2009 you know i was just joking GD come on now :-p GeneralDisorder said: And when your $hitbox burns to the ground because of your hokey wireing practices and all the other piss-poor wrenching that you have done - don't blame this board - please go directly to Crayola's house and ask his mom if he can come out to play GD Link to comment Share on other sites More sharing options...
