Loyale93v Posted December 10, 2009 Share Posted December 10, 2009 My 1999 2.2L SOHC Legacy Brighton Wagon is a PHASE II engine; Is that correct? Manufacter date of: 8/99 , PHASE I is '90 - 98, and PHASE II is '99 only? Is this correct? Link to comment Share on other sites More sharing options...
idosubaru Posted December 10, 2009 Share Posted December 10, 2009 Yes, sounds like you got it right. I don't believe it's just a single year though - the 99-2002..or whenever the last year for the EJ22 was should all be Phase II and interchangeable with minor adaptations if any at all. If you're familiar with the Phase I motors, it's really easy to tell just by looking, the newer ones look a good bit different, it's not like it's "hard to tell". The spark plug wire position is a dead give away. Link to comment Share on other sites More sharing options...
OB99W Posted December 10, 2009 Share Posted December 10, 2009 Yes, Phase II engines went into the '99 models. However, there were some less extensive changes in '97 that made the 2.2 an interference engine, if that's a consideration. Link to comment Share on other sites More sharing options...
johnceggleston Posted December 10, 2009 Share Posted December 10, 2009 PHASE II is '99 only? Is this correct? correct for legacy, impreza used the 2.2 in '00 and i think '01. . Link to comment Share on other sites More sharing options...
