Hey "the group", I took some pics of a timing belt/ cam switch job.
heres the link to the pics
http://www.facebook.com/photo.php?pid=66521&l=5b48c08a6b&id=100000515483785
This way you can hold the cam gears so that you can torque them correctly.
This is the old timing belt.
MAKE SURE YOUR CRANK GEAR'S TIMING MARK IS LINED UP.
When the crank gears mark is up the pistons are 1/2 the way down so that the pistons can't hit the valves if the cam turns too far. :)
