I recently put in a tranny on my 1996 outback. Everything is fine except when I start out, or when I gear down. When depressing the clutch in 1st gear it grabs too much. So I need to dump or feather the clutch, which I hate to do. I've been told it might be my "spring thingy":lol: (forgot what he said). I only replaced the disc, not the hardware, a friend said it wasn't necessary, and the kit costs....So ye experts, fools, and would mechanics, harken please to mine call.. You guys have been so helpfull so far!!!!:banana:, Oh, and my wife is taking the car to get a "free" check up at a tranmiision place:-\, EEK!!! Thanks Dann
Was it the pressure plate? If the pressure plate is scored or has hot spots, it could be causing the vibration/shudder you're describing.
It's usually good practice to replace the pressure plate with the clutch disc. It's also good measure to replace the pilot & throw out bearing as well.
  • 3 years later...
My Sube has a similar problem with a lot of chatter/shudder on a downshift.  Recently, I got my exhaust patched (there was a pretty big gaping hole in the segment between the 1st and 2nd cat converters).
The car runs quieter now, a little warmer and there is much more pickup on acceleration.  But also now that shudder problem has practically disappeared!
I guess the additional back pressure also solved a mechanical problem...the leaky exhaust probably causes a serious aspiration problem even when decelerating.
--Damien
