SOUTHPARK SLIM Posted December 12, 2009 Share Posted December 12, 2009 Got my 2" e82 lift today and it really looks well constructed. I got the rear shock extenders installed in about an hour, no problem. I assume the (6) 13mm X 1 1/4" bolts are for the front strut extensions, the (4) 14mm x 5" bolts are for crossmember drop blocks (i figgured this out by the 2 holes in each block, so easy a cave man could do it) I cannot figgure out where the (4) 17mm x 2.5" bolts go or the (4) 5/8 long nuts go. I would appreciate any input on where these are supposed to go. Also should i disconnect the steering shaft before lowering the crossmember?....................thanks Link to comment Share on other sites More sharing options...
Turbone Posted December 12, 2009 Share Posted December 12, 2009 Have you contacted Scott, the guy who makes the lift? Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted December 12, 2009 Share Posted December 12, 2009 SOUTHPARK SLIM said: I cannot figgure out where the (4) 17mm x 2.5" bolts go or the (4) 5/8 long nuts go. under the rear mustache bar wear it mounts to the body, drops the diff down 1" Link to comment Share on other sites More sharing options...
SOUTHPARK SLIM Posted December 12, 2009 Author Share Posted December 12, 2009 thanks scott..off to the garage................... Link to comment Share on other sites More sharing options...
