Ahaaahhahaha it lives(now what to do about mouse nest)
ALLRIGHT!!!! Thanks for everyones help. I got my new 86 GL started today. Turns out the idiots installed the timing belts wrong and the distributer. I still dont have it perfect, but it is driveable. I need to get a timing light to see if I can get it timed to spec. I might be a tooth off on the Dist. I rattles and pings pretty well under heavy throttle. ALL IN ALL IM PLEASED AS HELL:banana::lol:. The headlights stopped working some place along the test drive, seems to be in the switch. Turn signals are a little picky but work. I noticed a clicking noise from under the hood. It is comming out of a solenoid on the pass. side fender. Looks like it had a vacume hose on it at one time. It is next to a little black box that says BOOST on it(HMMMM). The ECU light came on every once in a while, I will research what to do with it. The only real problem I can see now is the mouse nest in the heater:eek::mad:. Any tips or tricks to getting it out as well as the smell?:)
Anywho, thanks alot guys.
Mike
Spray the nest with WD-40 (if you can get to it) and reach up there with a glove on..like a dish washing one, and a mask over yer face hole. Them nests are nasty and full of unhappy:eek:. (The WD-40 keeps the dust down and the particals out of your lungs.)
as far as the rest. I dunno.
But yes time it..get a light and do it.
I'm glad things are looking up. Before you know it you'll be shopping around for a lift and some Pugs. :banana:;
That would be great rob. I didnt realize how expensive timing lights were.:eek: I went out and started it again tonight, couple of pumps on the gas and it fired right up into a high idle.YAY. Gave it a couple minutes and kicked it down. Not bad at all. I have to go to bonney lake to transfer the title and gets tabs this week. Is there a day that would work well for you?
Thanks rob
Mike
