Removing Castlated nut, concave washer, SPLIT CENTER PIECE, '84 GL help please
mkoch
(edited to say, problem solved)
Greetings all,
Here is a photo of my replace-the-rotors project. The photo is of the passenger side front axle, and split center piece.
My problem is, the split center piece just won't come out. I've tried the hammer/cold chisel around the perimeter method. It is still stuck.
Does the split center piece have to come out before I use the drum puller? I don't want to use the drum puller (disc puller in this case) if that will only force the cone tighter.
Edited by mkoch
problem solved
After I posted, I added difluoroethane (Blow Off brand, canned propellant) to the cold-chisel attack. That Blow Off stuff is cold!. It took about a minute to chill the split cone, then it came off. No puller needed!
Sorry for the needless question.
