Gloyale Posted April 4, 2010 Author Share Posted April 4, 2010 All done. Installed int the car and it drives great. The one concern I have is the fluid filter. The Original H6 trans had a bypass cap bolted on instead of the spin on filter. The Forrester case that I used had the threaded pipe installed for a filter. In order to install the bypass cap from the H6, I would've needed to remove that threaded pipe for the filter, because that where the bypass bolt would go. So I left the filter there. Problem is, the H6 exhaust hits the filter. At least the heatsheild for the CAT. So I hammered a dent in the heatshield. It doesn't touch now, but the filter is DIRECTLY over the Cat. I am a bit worried about heat. I will have to remove the filter after a few days and inspect it for any signs of overheating. Otherwise the "hybrid" H6/Forrester trans is working fine. Link to comment Share on other sites More sharing options...
