Adjustable struts on my 86
backcountrycrui
So this new '86 wagon I got has the struts that you can adjust ride height with. Both front and rear. I was at Turbone's place today doing the timing (thanks again rob) and he was mentioning that I should lower them down a little to save the axles. I have a home made 2 inch lift ready in the garage, is it safe to use it with these struts. Should I lower the adjustments all the way down or can I keep them someplace in the middle and add the two inch block lift? Or should I forget about the block lift and just keep the strut adjustment cranked up? I guess it all depends on the ride height as it is currently. I think it is higher now than my '90 loyale(non adjustable). I would say by an inch give or take.
Thanks
Mike:-\
