xbeerd Posted December 17, 2009 Share Posted December 17, 2009 so, has anyone ever tried to run 2 alternators? maybe install an alternator in the spot of the AC compressor? it'd probably take a custom bracket but maybe it'd work? just a thouht. curious as to what others (that know more about this stuff than i) think. Link to comment Share on other sites More sharing options...
Scoobywagon Posted December 17, 2009 Share Posted December 17, 2009 I've seen cars with multiple alternators. There's a time and a place for that, but the reality is, most of us just don't draw that kind of current. Frankly, if you're just looking for more charging capacity, go with a high output GM Big case alternator. the 22SI (?) can be had producing over 140amps at idle. If you want to do something like that, check out alternatorparts.com. YOu can get some really manly alternators there. Like out past 300 amps manly. And unless you're running a HUGE stereo system or a large winch or enough lights to keep up with the lighting demands of a small city, like...say...Portland....you're unlikely to need more current than that. and if you do, you can get more than one. Link to comment Share on other sites More sharing options...
xbeerd Posted December 17, 2009 Author Share Posted December 17, 2009 I've seen cars with multiple alternators. There's a time and a place for that, but the reality is, most of us just don't draw that kind of current. Frankly, if you're just looking for more charging capacity, go with a high output GM Big case alternator. the 22SI (?) can be had producing over 140amps at idle. If you want to do something like that, check out alternatorparts.com. YOu can get some really manly alternators there. Like out past 300 amps manly. And unless you're running a HUGE stereo system or a large winch or enough lights to keep up with the lighting demands of a small city, like...say...Portland....you're unlikely to need more current than that. and if you do, you can get more than one. yeah i was mainly thinkin of for those who happen to have an extra alternator layin around and want to run a bunch of lights concurrently along with other gadgets etc. for the work involved i guess a GM/Nissan swap would probably be the better option. Link to comment Share on other sites More sharing options...
bheinen74 Posted December 17, 2009 Share Posted December 17, 2009 an extra pulley to turn take even more HP from the small HP we have from the Subaru factory. Just have a pro alternator rebuild shop custom rewind the stock alternator....for more amps.....do it and you will be happy. for less. Link to comment Share on other sites More sharing options...
Markus56 Posted December 17, 2009 Share Posted December 17, 2009 Do the Nissan swap and you will be happy. The GM one isn't worth the hassle for the extra 10 amps. Link to comment Share on other sites More sharing options...
Scoobywagon Posted December 17, 2009 Share Posted December 17, 2009 10 extra amps? Your stock alt is good for about 65 amps. GM big case alt is good for 140 amps and up. So that'd be a 75 amp increase. The GM one isn't worth the hassle for the extra 10 amps. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 17, 2009 Share Posted December 17, 2009 (edited) He means the Maxima Alt - they are 90A. GM swap isn't worth it for the 100A version is what the reference is too. The large case GM's that do super-high output are just rarely needed unless you are running serious draw. The bigger you go, the more the neccesity to upgrade some of the harness to avoid potential issues with high current draw and overloading your wiring. If the battery is low for example - the alt now has the ability to melt your harness as the battery will have no issue drawing whatever the alt will push - bigger alt, bigger push. Stock alts are 50A for EA81, 55A for EA82. GD Edited December 17, 2009 by GeneralDisorder Link to comment Share on other sites More sharing options...
Markus56 Posted December 17, 2009 Share Posted December 17, 2009 Thanks for the correction, GD. Got my cars mixed up Link to comment Share on other sites More sharing options...
