wolfeel Posted February 5, 2004 Share Posted February 5, 2004 What is the name of the gasket the is located on the engine block, behind the flyweel? It is kinda like an oil pan gasket (it in fact does seals oil). There is a mettle plate that fits over the top of the gasket anbd is held with like 6 bolts that are just like the oil pan bolt. This gasket was included in a Oil gasket set that included the pan gasket, mickey mouse gasket for the oil pump and a few more. Any names for it????????? Link to comment Share on other sites More sharing options...
Skip Posted February 5, 2004 Share Posted February 5, 2004 Wolfeel, the pan you speak of is only found on turbo cars (maybe MPFI also) it is just a passage way for fumes coming off of the oil in the oil pan so they can be drawn into the PCV system. Look on a turbo car you will see a nipple on the back almost center of the block. This goes into the volume under the pan you question. Under the pan at the bottom you will see an opening into the oil pan. Fumes pass up through the pan and into the PCV system. Hope this helps. Huffamoose?? Link to comment Share on other sites More sharing options...
MilesFox Posted February 5, 2004 Share Posted February 5, 2004 the gasket you refer to is only on turbo motors. if you get the complete gasket set from NAPA, it will be included. the gasket and cover are part of the PCV system, where the pcv line goes into the top of the block here are some NAPA parts numbers, and soob parts guide genuine parts numbers NAPA genuine parts no. 85 up Link to comment Share on other sites More sharing options...
WJM Posted February 6, 2004 Share Posted February 6, 2004 tell you what miles, that gasket set ran me a pretty penny, and I WORK there and got the 10% over cost discount. And the headgaskets blew in 4 days. lol Link to comment Share on other sites More sharing options...
Marck Posted February 6, 2004 Share Posted February 6, 2004 according to my 87 FSM the cover is called the 'oil separator cover' and the gasket is called the 'oil separator cover gasket'. Hope that helps. Link to comment Share on other sites More sharing options...
svxpert Posted February 6, 2004 Share Posted February 6, 2004 gasket- oil separator cover turbo only 11832aa001 85-88 11832aa002 88-90 engine numbers 557731-up part number is superceeded they only use the 002 now. Link to comment Share on other sites More sharing options...
Partsman Posted February 6, 2004 Share Posted February 6, 2004 BTW Miles - The part number on the timing cover set is JV1028, not JU1028 Nice looking page! Link to comment Share on other sites More sharing options...
MilesFox Posted February 6, 2004 Share Posted February 6, 2004 cool. glad u like. if you got any good parts numbers napa specific, i can put them on the page, if you would like me to do that Link to comment Share on other sites More sharing options...
RedRX Posted February 7, 2004 Share Posted February 7, 2004 Oil Separator???? Would this be the thing that fails to stop oil finding its way into the manifold, turbo, and cylinders? What is it supposed to do and how? Link to comment Share on other sites More sharing options...
WJM Posted February 7, 2004 Share Posted February 7, 2004 no, that woudl either be the PCV valve, or the turbo seals are leaking in the compressor housing. Mine is getting oil all over the place past the turbo...I have not bothered to investigate....yet. Link to comment Share on other sites More sharing options...
wolfeel Posted February 7, 2004 Author Share Posted February 7, 2004 Thanks for helping identify the name. By doing a web search first using the name "oil separator cover gasket" and other searches with a name close to that I could not find any results. I also tried searching part vendors web pages using their category search and typing in the gasket name and could not find anything. Does anyone know where I can find on online? I will check my local parts supply shop and then if they can't help I will most likely go to the dealer or just make it out of cork board. Thanks again for all the help!! Link to comment Share on other sites More sharing options...
svxpert Posted February 7, 2004 Share Posted February 7, 2004 <<Does anyone know where I can find on online?>> http://www.subaruparts.com/cart/?pn=11832aa002&submit.x=13&submit.y=5 Link to comment Share on other sites More sharing options...
wolfeel Posted February 8, 2004 Author Share Posted February 8, 2004 Thank you! Link to comment Share on other sites More sharing options...
