the EJ is not going to fit! (Loyale)
I figured I would have to remove the plastic panel, however what am I going to see when I get it open, is this something I am going to need more then just a replacement handle for?
Sorry for being difficult, I just would like to hear from people that have done this before I rip into the rear hatch.
Thanks
Thanks Bill
Got it!
One last question, would you happen to remember the way the clips want to release on the hatch (lift up, down, side, etc.)?
if you are asking about the clips that hold the cover in place, they come straight out - just need to be careful not to break them as you pull (they tend to want to snap from age) I may be able to provide a few replacements if needed since i am stripping my old wagon...
if you have one available, one of those wide panel puller things work pretty well, just be gentle.
Once you get the cover off, it is pretty easy to see what needs to be done. the hardest part is getting the rod unhooked from the handle - needle nose pliers and a bit of effort is required - might i suggest lubing it up with a little oil to help ease things along...I also recommend pulling the rod BEFORE you unbolt the handle...
Well that was easy! I picked up a new handle from Subaru (about 30bucks) it took me less then 10 minutes to install.
I just pulled (literaly) the interior panel off,
removed two nuts holding the handle on,
removed the broken platic handle from the metal rod (make sure you remember which side the metal rod was on!),
installed the new handle,
pressed the metal rod into the plastic retainer on the plastic arm of the handle,
reinstalled the interior panel. bada bing!
Only thing I would add is that YOU ARE GOING TO BREAK a few of those dried up little clips that hold the interior panel on(unless someone has been rubbing them with a silicon cloth or glycerol or something lol) so plan on a trip to the autoparts store!
Edited by SuperchargedRS
