oskar_subaru Posted December 19, 2009 Share Posted December 19, 2009 ok so i bought a 1987 GL sedan and the heater is not working on any speed, i think the switch works because it turns the light on the vent selector on and of between 0 and 1 the motor turns if i give it power, is there any resistor packs outside the switch it self ? Link to comment Share on other sites More sharing options...
eulogious Posted December 19, 2009 Share Posted December 19, 2009 Yup, a common problem... search for it, it comes up quite often Link to comment Share on other sites More sharing options...
KristjanJohann Posted December 19, 2009 Share Posted December 19, 2009 that´s the thing, maybe it´s my english knowledge but i don´t find anything when i try to search for this oskar_subaru Link to comment Share on other sites More sharing options...
Dylan86GL10 Posted December 20, 2009 Share Posted December 20, 2009 For info on the resistor pack: EA82 Blower Resistor Pack Info http://www.indysworld.com/80s/general/USRM/mick-usrm/resistor-pack/resistorpack.html The blower should have 12v+ from fuse 1, 2, 12 and the switch should control the grounding to the motor (through the resistors to control speed) Hope this helps Link to comment Share on other sites More sharing options...
TRAVIS75 Posted December 21, 2009 Share Posted December 21, 2009 I had same problem, ended up just being blower motor resistor located right by the blower motor. I always thought it was a progressive failure, losing high, then next highest etc...etc... mine just flat quit working. Link to comment Share on other sites More sharing options...
SuperchargedRS Posted December 22, 2009 Share Posted December 22, 2009 If it doesn't work on ANY speed it's probably the motor. Turn the car on, put the selector to max (I think it is "4" or something) and check for 12vdc at the blower (it's to the left pax side). Link to comment Share on other sites More sharing options...
ivantruckman Posted December 22, 2009 Share Posted December 22, 2009 If it doesn't work on ANY speed it's probably the motor. Turn the car on, put the selector to max (I think it is "4" or something) and check for 12vdc at the blower (it's to the left pax side). or possiably the relay itself Link to comment Share on other sites More sharing options...
oskar_subaru Posted December 23, 2009 Author Share Posted December 23, 2009 or possiably the relay itself you get the dancing banana tried switching one of the headlight relays for the heater one and surely enough the motor started blowing like a champ (was hoping it wasn't the motor, the car is only driven 102.000 km (60.000 miles)) thanks all though for great response, this forum never seizes to amaze sorry about my spelling Link to comment Share on other sites More sharing options...
