Mr Whiskey Posted December 19, 2009 Share Posted December 19, 2009 (edited) What would make both right side cyl's intermittant? Could electronic ign module or pick up cause this? Spark looks weak to me. Seems like something is gettin hot and breaking down. Has good compression, will run fine on 4, just keeps cutting the right 2 out at the same time. Injectors are spraying. Plugs and wires are good. Cap and rotor button look fine. Most of this is written up in my other post but it seems we're chasing more than one prob so I thought I'd try a new one. 85 gl10 waggon, ea82 auto, mpfi, front whl. only. Thanks to all in this community, my Son and I couldn't have gotten as far as we have without y'all, peace. Edited December 19, 2009 by Mr Whiskey Link to comment Share on other sites More sharing options...
idosubaru Posted December 19, 2009 Share Posted December 19, 2009 are you talking about spark? what do you mean and how do you know? how intermittent and any correlation - temperature, humidity, first start or after it's warm? and what engine - is this carb or FI? Link to comment Share on other sites More sharing options...
Mr Whiskey Posted December 19, 2009 Author Share Posted December 19, 2009 Sorry, forgot that part, MPFI. We've pulled the plugs and cranked the car to check spark, looks yellow/orange, not good blue/white. Car will start on left 2 cyls, then pick up the right 2 as it gets warmer, then drop them back out just going 'round the block. Thanks, peace. Link to comment Share on other sites More sharing options...
Uberoo Posted December 19, 2009 Share Posted December 19, 2009 check your spark plug wires.They may be arcing out on that side with each other or the block itself. It helps to look at the engine while its dark and look and see if its arcing somewhere... Link to comment Share on other sites More sharing options...
Mr Whiskey Posted December 19, 2009 Author Share Posted December 19, 2009 Please forgive me, I expect I'm not doing this right, but as we get further into the diagnosis of this vehical I'm finding it necessary to start new post, as what I thought I knew changes. Please don't hold it against us, my Son and I, we're new to this. We appreciate all the valuable experiance here and are truly thankful for all who are tring to help. We hope you might read our newest post "No compression right front cyl/120 psi right rear " and continue to provide your insites and expertise. Thanks to all, peace. Link to comment Share on other sites More sharing options...
