bheinen74 Posted December 21, 2009 Share Posted December 21, 2009 How is the best way to blow a 30amp newer mini spade type fuse? I want to make the ABS light stay on with the fuse in place i am thinking jumper cable neg to one spade and jumper cable positive to the other spade, and boom, does that seem right. Link to comment Share on other sites More sharing options...
Legacy777 Posted December 21, 2009 Share Posted December 21, 2009 That should work. Not sure if it's the best, but it will work. Link to comment Share on other sites More sharing options...
987687 Posted December 22, 2009 Share Posted December 22, 2009 That would work. But I wouldn't get jumper cables so close together like that. One slip and boom goes your battery. Seen it happen not 20' from me. Not a pretty sight. I'd probably put the fuse in a fuse holder, nice long leads, then short those to the battery. Link to comment Share on other sites More sharing options...
ronemus Posted December 23, 2009 Share Posted December 23, 2009 The easy AND safe way would be to drill a hole through the side to cut the connection - no chance of excessive current, inadvertent arc welding, etc. Just cut the narrow bit that connects the two tabs. I'd guess that a 1/8" drill would do the job nicely and leave enough of the body intact that it would hold together well. Link to comment Share on other sites More sharing options...
forester2002s Posted December 23, 2009 Share Posted December 23, 2009 Am I missing something? Why not just remove the fuse? Link to comment Share on other sites More sharing options...
johnceggleston Posted December 23, 2009 Share Posted December 23, 2009 this thread reminds me of how i used to identify which electrical circuit each receptacle was on. just short it out at the receptacle and then go look for which one popped. not the safest or most high tech approach. but really, why not just remove it?? Link to comment Share on other sites More sharing options...
edrach Posted December 23, 2009 Share Posted December 23, 2009 johnceggleston said: this thread reminds me of how i used to identify which electrical circuit each receptacle was on. just short it out at the receptacle and then go look for which one popped. not the safest or most high tech approach. but really, why not just remove it?? I remember a friend in high school that had a "shorting plug". Whenever he didn't have his homework prepared or wanted to avoid a class, he'd bring the plug with him and find an outlet. He never did get caught. Some people are jsut weird. Link to comment Share on other sites More sharing options...
Fairtax4me Posted December 23, 2009 Share Posted December 23, 2009 Short it with a couple wires attached to the battery terminals. Use a good size wire like 12-14awg and some spade connectors crimped to the ends. Link to comment Share on other sites More sharing options...
r_kirky Posted December 23, 2009 Share Posted December 23, 2009 you could put a five amp fuse in and wait a few seconds. Link to comment Share on other sites More sharing options...
bratman18 Posted December 23, 2009 Share Posted December 23, 2009 If you remove the fuse you are asking for problems if you ever get in a wreck and someone investigates. Chances are, no one will, but if they find you deliberately removed the ABS fuse and therefore had no working ABS, they might make a stink and then you insurance company will fight it all the way. Link to comment Share on other sites More sharing options...
