Recently picked this car up. Found out the rear brake line goes into the interior. Any suggestions on going about replacing this? Right now the car has no brakes, and it looks as if its leaking from the interior....
typically they go from the wheel well into / under the rear seat and then run along the floor of the car at the driver side door jambs.
lift he rear seat and you will likely find the leak. sedan or wagon, wagon is easier but neither is very hard. if you have to remove the rocker panels, bottom plastic pieces on door jambs, be careful not to break / snap any of the unseen tabs on the under side that hold them down.
Also. Just wondering if anyone knows the size of the brake line fittings on these. Is it that standard one used on japanese cars, or something different. If anyone knows the exact size that would be awesome, I wouldnt have to drive over to take one off of it. Planning on buying a roll of brake line and a bunch of fittings, If I see line I dont like, its getting replaced.
  • 7 months later...
