corvette6698512 Posted December 23, 2009 Share Posted December 23, 2009 My '83 GL just randomly pops itself into 4wd while driving. Its not like its rarely either. Once its in 4wd, its hard to put back into 2wd also. Is this a common thing on the older GL's? Its a 4 speed. I'm planning on doing a 5 speed swap, but like everyone else, no money to cover the cost of that quite yet. I probably wont have the money for a while, so I want to get this figured out. Thanks! Link to comment Share on other sites More sharing options...
rxleone Posted December 24, 2009 Share Posted December 24, 2009 I've never heard or seen that happening, and me and my brother have both owned a few ea81s (mainly ea82s though ) My advice would be to swap out the 5spd ASAP. (Pretty useless I know ) Link to comment Share on other sites More sharing options...
TomRhere Posted December 24, 2009 Share Posted December 24, 2009 My guess would be bad motor and tranny mounts. Those would let things flop around enough to pop it into to 4WD. Just my .02 Link to comment Share on other sites More sharing options...
Gloyale Posted December 24, 2009 Share Posted December 24, 2009 TomRhere said: My guess would be bad motor and tranny mounts. Those would let things flop around enough to pop it into to 4WD. Just my .02 Second that. And also the lever might be adjusted too tight. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 24, 2009 Share Posted December 24, 2009 Yep - very likely bad tranny mounts and don't overlook the pitching stopper - that negates exactly the kind of movement that would cause your problem. GD Link to comment Share on other sites More sharing options...
corvette6698512 Posted December 25, 2009 Author Share Posted December 25, 2009 Pitching stopper? Where would that be? It does need new trans mounts though. Link to comment Share on other sites More sharing options...
TomRhere Posted December 25, 2009 Share Posted December 25, 2009 It's just left of center where the engine/trans bolts together and runs back under the spare tire mount. Link to comment Share on other sites More sharing options...
wysei82 Posted December 27, 2009 Share Posted December 27, 2009 Maybe she just thinks she's an AWD Link to comment Share on other sites More sharing options...
corvette6698512 Posted December 29, 2009 Author Share Posted December 29, 2009 So i was messing with the 4wd and it got stuck in 4 low. The shifter pushed down but didnt put it in 2wd, so i climbed under the car and pulled the rod into 2wd. Turns out the nut for the shift linkage came off. So now everything fells way better, no more slop and it hasn't popped into 4wd. The 4wd light stays on though(even if its in 2wd). Where is the switch for the 4wd light located? Link to comment Share on other sites More sharing options...
corvette6698512 Posted January 2, 2010 Author Share Posted January 2, 2010 Nobody knows? Maybe a way to adjust the 4wd shift bar so the shifter is pushed down further when in 2wd? Link to comment Share on other sites More sharing options...
corvette6698512 Posted January 6, 2010 Author Share Posted January 6, 2010 Extended the 4wd shift rod. Easy fix. Link to comment Share on other sites More sharing options...
MAD MAX Posted January 6, 2010 Share Posted January 6, 2010 Glad it worked for you Link to comment Share on other sites More sharing options...
eulogious Posted January 6, 2010 Share Posted January 6, 2010 Don't you love it when the easiest solution is the best? Glad you got it working! Now just don't go running it into stuff and you should be all good! Link to comment Share on other sites More sharing options...
bertaru Posted May 11, 2010 Share Posted May 11, 2010 do you have a actual 4WD shifter or is it one of those vacuum operated push buttons on the shifter? if its a push button, check the switch and the vacuum solenoids. having a similar issue but its really intermittent. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted May 11, 2010 Share Posted May 11, 2010 1: He already solved the problem. 2. EA81's and older (that's all models through '84) are all rod-shifted. They did not make a push-button except for the automatic's. GD Link to comment Share on other sites More sharing options...
