ea81 build...
whoa... first post on here in ages but good to be back! Anyways,
I'm in the process of rebuilding an ea81 for an '83 GL I will probably end up buying from a friend. So far what all I've done is strip the heads off and sent them off to a buddies machine shop to take 0.020" off the heads and do the valves. I haven't yet torn into the bottom end, but I have all the bearings and seals from a kit I bought years ago that i never ended up using. My goal is to get a better overall performing engine but nothing crazy, its going to be a daily driver/farm vehicle.
I have some more searching to do, I am currently looking for suggestions on what to do with the bottom end on this motor and the cam, I'd like to modify it but I have limited knowledge of cams and what would be appropriete lift, duration and timing etc... to get the best results, I'd like to have a bit more torque in the lower RPMs since it will see a lot of driving off road and in heavy snow.
I've also thought of dropping in an ej22 a friend built for a '92 LSI but I really want to hold that project for my 2wd hatch with an ea71 when that thing blows....
