Loyale93v Posted December 25, 2009 Share Posted December 25, 2009 (edited) today while checking the oil level {which by the way, leaks from an array of places..but thats a story for a different day} So I lifted off the oil cap and underneath on the inside of the cap was a mayo like substance..not allot but noticeable. I checked the oil level, it was half way between full and low. I topped it off. The coolant overflow res was a little low also, again not very low but noticable. { I keep a close eye on my cars being an auto tech by trade} I don't suppose this is normal. The intake gaskets are leaking a trickle of coolant. Is it safe to say that the intake gasket and the emulsification on the oil filler cap is related? Edited December 25, 2009 by Loyale93v Link to comment Share on other sites More sharing options...
lostinthe202 Posted December 25, 2009 Share Posted December 25, 2009 I guess you're talking about a 93 Loyale as your name suggests, but type of vehicle, miles, etc. will be helpful. Link to comment Share on other sites More sharing options...
Loyale93v Posted December 25, 2009 Author Share Posted December 25, 2009 UPDATE: I cleaned off the oil filler cap and let the car idle for 30 min or so and checked it again. There is beads of moisture on the inside of the cap. ( I bet it is coolant burning off) how bad is it doctor? i dont know but I have had a set of intake manifold gaskets in the drawer for a few months now...maybe it is time to R & R ! anyone...? MERRY CHRISTMAS EVERYONE!!! Link to comment Share on other sites More sharing options...
Loyale93v Posted December 25, 2009 Author Share Posted December 25, 2009 I guess you're talking about a 93 Loyale as your name suggests, but type of vehicle, miles, etc. will be helpful. OOPS ....yeah sorry. * 93 loyale, EA82, 2WD, 70,000k * Link to comment Share on other sites More sharing options...
Scoobywagon Posted December 25, 2009 Share Posted December 25, 2009 It is possible that the emulsification you saw is related to leaking intake manifold gaskets. But I doubt it. There's not a particularly good way for coolant to enter the crankcase from the intake manifold unless it is continuously running past the rings while the car is parked. Link to comment Share on other sites More sharing options...
nipper Posted December 25, 2009 Share Posted December 25, 2009 And how old is your PCV Valve? Link to comment Share on other sites More sharing options...
ivantruckman Posted December 25, 2009 Share Posted December 25, 2009 in the cold northeast. Michigan at least, i get the same problem. if i make allot of short runs. i live about a half mile from work. when i run the car for a long time it boils off the water Left by condensation and goes away. Link to comment Share on other sites More sharing options...
Loyale93v Posted December 26, 2009 Author Share Posted December 26, 2009 And how old is your PCV Valve? PCV age unknown; I bought car last May , with 58,000 miles on it. I haven't changed it. It must be original. i notice this car has alot of blowby. Link to comment Share on other sites More sharing options...
Russ Hill Posted December 26, 2009 Share Posted December 26, 2009 It's condensation, very common in cold weather. If you had coolant in the oil it would look like pancake batter (trust me :-\ ) change the PCV valve. Also, pull off your PCV line and valve then, take some stiff wire and make sure that the fitting going into the intake and the rubber line is clear. The PCV port and line tend to get blocked by carbon, this causes crank case pressure to build up. This could be the source of your oil leaks. Link to comment Share on other sites More sharing options...
