Gene J Posted December 25, 2009 Share Posted December 25, 2009 My 98 GT starter sometimes makes no noise when U turn the key. Not even a click. When the starter does turn it is just fine. A search revealed that it may be the starter contacts. Do the experts here concur? I need to know because it VERY cold outside where I will have to do the work. Why don't these things happen in the summer? Link to comment Share on other sites More sharing options...
lmdew Posted December 26, 2009 Share Posted December 26, 2009 Sounds like contacts, but make sure the battery cables are clean and tight. The starter is easy to remove, and take inside. 14 mm bolt up top, 17 mm nut on the bottom and a 12mm nut for the cable. Link to comment Share on other sites More sharing options...
edrach Posted December 26, 2009 Share Posted December 26, 2009 Another possibility is the connector from the ignition switch into the harness. Usually a pink or white plastic connector about 6 inches from the ignition switch. You'll have to remove some of the plastic shroud under the steering column to see it. The tip off is that if it has a poor connection on one of the wires, it will heat up the plastic and turn that area brown or black. Contact cleaner will likely be a temporary fix; permanent fix is a new cable harness....very cheap at the pull a part yards. Hopefully this is it since it's warmer fixing this than removing the starter and checking the contacts. Link to comment Share on other sites More sharing options...
Hendrik Posted December 26, 2009 Share Posted December 26, 2009 (edited) Happened to me once , was the ignition switch with internal poor contacts. Opened it up and cleaned it. Should have contact resistance below 0,1 Ohm Edited December 26, 2009 by Hendrik Link to comment Share on other sites More sharing options...
naru Posted December 26, 2009 Share Posted December 26, 2009 My 98 GT starter sometimes makes no noise when U turn the key. Not even a click. When the starter does turn it is just fine. A search revealed that it may be the starter contacts. Do the experts here concur? I need to know because it VERY cold outside where I will have to do the work. Why don't these things happen in the summer?[/quote No,since there is no click,the solenoid is not working and the contacts do not do anything. Could be bad ign. switch as suggested or bad stater brushes. Solenoid pull-in coil recieves current thru the brushes so if they are bad,no click.(recently had the same problem). If it works when you jump the solenoid terminal to the large battery wire on the starter,ign. switch,nuetral safety switch or clutch switch are likely culprits. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 27, 2009 Share Posted December 27, 2009 The most common cause on the newer gen stuff is just plain poor battery cables or terminals. Especially in this cold weather - the cable's shrink away from the crimp joints and terminals get loose. GD Link to comment Share on other sites More sharing options...
Gene J Posted December 30, 2009 Author Share Posted December 30, 2009 The answer is???? Battery. The starter etc was just fine. I thought it was odd since all of the electrics worked fine. I even tried to jump the battery and nothing happened. I replaced the battery and all is fine. Link to comment Share on other sites More sharing options...
