Loyale93v Posted December 26, 2009 Share Posted December 26, 2009 R & R rear drums, left e-brake frozen. I disconnected it. Now right rear is rubbing when I apply the pedal. any advice on adjustment? Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted December 26, 2009 Share Posted December 26, 2009 Guess I am confused..........isn't the shoe suppose to rub when the pedal is applied? The "star" wheel, is where tightness is adjusted. E-brake cable rusts inside the tubular housing is what I have observed as the reason the e-brake freezes. I replaced the cable on a VW some time back with brake shoes, it was difficult job requiring a lot of cussing during the process of hooking up the cable. It required a lot of cable stretching, but it can be done as a one man job. Quote Link to comment Share on other sites More sharing options...
Loyale93v Posted December 26, 2009 Author Share Posted December 26, 2009 Guess I am confused..........isn't the shoe suppose to rub when the pedal is applied? yes, but it is rubbing un evenly. More like a scrape-scrape-scrape.. I adjusted the star wheel at time of install. It felt like it had the proper drag on the drum before I put the wheel/tire back on. I don't get why it is doing this. Quote Link to comment Share on other sites More sharing options...
lmdew Posted December 27, 2009 Share Posted December 27, 2009 The E-Brakes are attached to a Tee under the center counsel. With one attached, it can effect the brakes as the cable is attached while the other one is cut. Did you remove the cut cable and lever? If not it may be the source of your noise. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted December 27, 2009 Share Posted December 27, 2009 adjust it. there's a wheel - pull them off so they're not rubbing. if that's not doing it then pull the rotors, have them turned and reinstall. they might be rusted bad or you might find something else wrong when you get in there. Quote Link to comment Share on other sites More sharing options...
Loyale93v Posted December 27, 2009 Author Share Posted December 27, 2009 The E-Brakes are attached to a Tee under the center counsel. With one attached, it can effect the brakes as the cable is attached while the other one is cut. Did you remove the cut cable and lever? If not it may be the source of your noise. I disconnectd the left side e-brake cable from the shoe inside the drum. The right side is still attatched. hhhmmmm.:-\ Quote Link to comment Share on other sites More sharing options...
