EJ22 to Gen II Brat
Mr. Brat
no you don't need a motor out of a manual car...the one i have in my Brumby/Brat is out of an auto.
once you take the flexplate or clutch off there isn't difference as far as i know
as for the ECU differences i would think an auto one could be made to work by making the ECU think its in neutral or park however i wouldn't know...i have a factory dizzy an LPG carb on my one
I put an EJ into my GL wagon that was attached to an automatic - just pulled the flexplate off and bolted the EA flywheel up (after some grinding on the bolt holes). I don't think there are any computer differences - the legacy had a separate tranny control unit. The only difference I can think of with the wiring between the auto and the manual is a neutral safety switch on the auto and a clutch safety switch or some such thing for the manual trans.
