DavieGravy Posted December 30, 2009 Share Posted December 30, 2009 I have a gas leak in my Legacy as shown in the picture in the below link. Does anyone know how hard this will be to fix? I've circled the gas drips in the picture. http://www.yousendit.com/transfer.php?action=check_download&ufid=TzY2Q3R6aytKV09Ga1E9PQ&key=41858a9f254abd346917f5254d764ac7ea821deb&bid=VGllQmtTd0lVVGwzZUE9PQ Link to comment Share on other sites More sharing options...
Rooster2 Posted December 30, 2009 Share Posted December 30, 2009 It is difficult to see much detail in the picture. Where under the car was this picture taken? I may be mistaken, but it appears to be a shroud on an exhaust pipe. If so, I doubt that it is gas dripping there. Link to comment Share on other sites More sharing options...
Allpar Mod Posted December 30, 2009 Share Posted December 30, 2009 R2 is right. It's nearly impossible to tell anything by the picture to try to help you. Just to take a shot in the dark, though, I'm assuming that the leak is from under the hood. If so, this could be anything from possibly being a bad o-ring on a fuel injector, the fuel rail itself, the fuel line at or near the fuel rail. None of these are particularly difficult DIY or expensive repairs if you have to have a mechanic do them. I'd make a significant effort to ID exactly where the leak is coming from because any fuel leak is potentially a dangerous situation. Link to comment Share on other sites More sharing options...
frag Posted December 30, 2009 Share Posted December 30, 2009 What he's showing us is the shroud around and under the fuel fill pipe. It's a frequent leak cause the shroud catches humid dirt and the fill pipe rusts. First thing to do is remove the shroud (plastic), clean the fill pipe and see where the leak is. Sand and repair with epoxy or special stuff made to fix fuel tank leaks. If it's bad enough that you have to replace the fuel fill pipe, report back and I will have some more advice to give you. Been there done that... Link to comment Share on other sites More sharing options...
MilesFox Posted December 30, 2009 Share Posted December 30, 2009 ^^^ second that, i have seen this fairly often, fill tube rusts out behind the shroud Link to comment Share on other sites More sharing options...
DavieGravy Posted January 3, 2010 Author Share Posted January 3, 2010 (edited) frag said: What he's showing us is the shroud around and under the fuel fill pipe.It's a frequent leak cause the shroud catches humid dirt and the fill pipe rusts. First thing to do is remove the shroud (plastic), clean the fill pipe and see where the leak is. Sand and repair with epoxy or special stuff made to fix fuel tank leaks. If it's bad enough that you have to replace the fuel fill pipe, report back and I will have some more advice to give you. Been there done that... I apologize that I didn't state specifically where the leak is. It's behind the gas tank next to the rear passenger wheel. Is this what you're referring to regarding the fill pipe?If so, I'll try your suggestion and post back. Thanks Edited January 3, 2010 by DavieGravy Link to comment Share on other sites More sharing options...
frag Posted January 3, 2010 Share Posted January 3, 2010 DavieGravy said: I apologize that I didn't state specifically where the leak is. It's behind the gas tank next to the rear passenger wheel. Is this what you're referring to regarding the fill pipe?If so, I'll try your suggestion and post back. Thanks Exactly! Link to comment Share on other sites More sharing options...
DavieGravy Posted July 3, 2010 Author Share Posted July 3, 2010 Finally got around to looking at this. The pipe is in fact rusted. There is a clear, visible small hole where the gas is leaking out of. I was going to try and patch it with JB Weld, but the problem is gas keeps coming through the hole and the JB Weld won't bond. I tried to depressuize the fuel system by disconnecting the fuel pump connector in the access panel in the back. The car eventually stalled but keeps starting and runs for a long time. Will the gas eventually stop coming out of the hole or will I need to completely drain the fuel tank? Is there a trick to quicly draining the tank while salvaging the gas? Thanks in advance. Link to comment Share on other sites More sharing options...
DavieGravy Posted July 5, 2010 Author Share Posted July 5, 2010 I stuck a small, rolled up piece of duct tape in the hole to stop the oozing gas. I was then able to conver it with the JB Weld. A second coat the next day finished the job. The pipe rusted out because of the accumulation of dirt on top of the rubber cover that goes underneath the metal pipe. I suspect leaks will occur again in the future but at least this fixed the problem temporarily. Link to comment Share on other sites More sharing options...
