hatchsub Posted January 3, 2010 Share Posted January 3, 2010 Possible to pull the engine and tranny as one unit? EA81 and 2wd 5 speed. Link to comment Share on other sites More sharing options...
TomRhere Posted January 3, 2010 Share Posted January 3, 2010 Yes it is. Drain the tranny 1st or you'll dump the fluid from it all over the ground. If you're talking of the engine/trans from your wrecked one, just cut the radiator support out of the way and you won't have to tip the assembly backwards as far. Link to comment Share on other sites More sharing options...
hatchsub Posted January 3, 2010 Author Share Posted January 3, 2010 This is a 2wd one just so you kno. The only place for the fluid to come out would be the dipstick at the front. Yea im talking the wrecked one and the new one. The wrecked one i probably will cut the support. Link to comment Share on other sites More sharing options...
idosubaru Posted January 3, 2010 Share Posted January 3, 2010 i've yanked engine and trans both as a lump in multiple Subaru's, the largest contraptions being: XT6 AWD's EJ25 AWD Auto's and AWD Manuals i'm guessing the tiny EA81 and FWD will come right out. only suggestion i have is to make it easy to angle/adjust the lump as you may need to increase the angle as you come forward. Link to comment Share on other sites More sharing options...
TomRhere Posted January 3, 2010 Share Posted January 3, 2010 Yeah, on the wrecked one. Pull the headlight assemblies from the radiator support, then cut down thru those over to the radiator area. Should give you plenty of room to pull everything on a basically flat pull to the front. You'll be able to see what needs to be removed just looking at it from the front. 2WD drive definetly makes it easier. Link to comment Share on other sites More sharing options...
