akc Posted January 3, 2010 Share Posted January 3, 2010 Ok so I am blind I know it is on here somewhere but I have spent the last 15 minutes looking to no avail. Problem my double barrel weber carb when we were moving it all over a spring popped out and I cannot figure out where it goes.. i just need a diagram to put her back together. It runs.... just not well. Ok so I can drive it but everyone looks at it like it is going to explode.. it sounds really bad.. Anyone know where any good weber diagrams are hiding? Spring is on passenger side of car. Sounded good till spring came out. Quote Link to comment Share on other sites More sharing options...
All4EA81 Posted January 4, 2010 Share Posted January 4, 2010 Is it a 32/36? Quote Link to comment Share on other sites More sharing options...
Uncle Ed Posted January 4, 2010 Share Posted January 4, 2010 Here try this link: http://www.carburetion.com/Weber/weberdiagrams.asp Ed Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted January 4, 2010 Share Posted January 4, 2010 if it is a 32/36 Like Mine, Check if there is the Return Spring on the Secondary Stage's Actuator... Kind Regards. Quote Link to comment Share on other sites More sharing options...
akc Posted January 4, 2010 Author Share Posted January 4, 2010 I think it is the 32/36 it is on a EA 82 engine. ..Thanks for the diagram I have seen this in the past but could not find it when I needed it....Will try to find the home for the spring. Maybe I can get her running DECENT again. "Check if there is the Return Spring on the Secondary Stage's Actuator" How would that make the engine run or what does it do? Just curious? Isn't it amazing what one little spring can do? Quote Link to comment Share on other sites More sharing options...
